How to convert MPKX to MPK?
8137
04-05-2021 10:11 AM
user91745
I made many maps in ArcGIS Pro and saved them as MPKX. I need to share these with people who do not have access to ArcGIS Pro. Is there some way to convert MPKX to MPK?
Thanks.
Robert_LeClair
Esri Esteemed Contributor
Here's a viable workflow if you want to go from ArcGIS Pro to ArcMap - How To: Import an ArcGIS Pro project to ArcMap (esri.com)
Robert_LeClair
To my knowledge, ArcGIS Pro packages (*.mpkx) are not backwards compatible to ArcMap packages (*.mpk).
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/map-package.htm
user91745
Ugh! So I have to remake all those maps in ArcMap??? There is no other path?
Robert_LeClair
user91745
@Robert_LeClair thank you for the info. Using AGOL looks generally viable, except it doesn't work with netcdf-based rasters. Anyhow, IMHO ESRI needs to put flashing neon warning signs on ArcGIS Pro telling users that it is not backward compatible. I've lost days of work because I assumed it was.... Now I need to re-create all my maps in ArcMap. Ugh...
Robert_LeClair
I understand the frustration of backwards compatibility and the issues presented if you have to go back to ArcMap.  Although not flashing in the AGP application, Esri does have an FAQ for ArcMap users to learn the workflow differences.  All the best!
