How to change symbol style with graduated colors
1517
02-26-2020 07:59 AM
BenjamenWetherill
This is a really simple question.  I am using graduated colors to define the color of points in a map.  How do I change the symbol style for the points?  In other words, how do I make the points larger?  If I have 10 color classes, the only method I can figure out so far is to manually change the size for each class.  I am using ArcGIS Desktop 10.5.
Tags (1)
RickeyFight
MVP Regular Contributor
Benjamen Wetherill
Yes I had that issue too. You can select them by clicking on the top one and holding shift and clicking on the bottom one.
Then chose the Properties for Selected Symbols
RickeyFight
Benjamen Wetherill
You can right click and choose properties for all symbols.
You might have to reapply the color ramp but it will change all symbols
BenjamenWetherill
Thank you for the reply.  When I do that nothing happens.  I click Properties for all symbols and nothing happens.  Here is my screenshot.  In your screenshot, all of the classes are selected.  How did you do that?
RickeyFight
Benjamen Wetherill
BenjamenWetherill
Thank you.  That works.  Properties for all symbols doesn't seem to do anything, but Properties for selected symbols with all selected works perfectly.
