How order data by column?
1368
04-20-2021 02:50 PM
Labels (3)
Radzhabad
There is a table with two columns. I want to sort it by 1st column, but there is a problem with the data type. Sort Ascending. If we make a column of type INT, then my slash will be lost. And if you leave it as STRING, the sorting is wrong.
INDEX;TEXT
2;ТП 12-4/2502-2-ЖБ
20;ТП 12-4/2502-20-ЖБ
2/1;ТП 12-4/2502-2/1-ЖБ
21;ТП 12-4/2502-21-ЖБ
3;ТП 12-4/2502-3-ЖБ
This is what you should get at the output.
INDEX;TEXT
2;ТП 12-4/2502-2-ЖБ
3;ТП 12-4/2502-3-ЖБ
How make it with SearchCursor
DanPatterson
It is called a "natural sort"
def natsort(text_lst):
    """natural sort returns text containing numbers sorted considering the
    :  number in the sequence.
    :originals used lambda expressions
    :  convert = lambda text: int(text) if text.isdigit() else text
    :  a_key = lambda key: [convert(c) for c in re.split('([0-9]+)', key)]
    import re
    def convert(text):
        return int(text) if text.isdigit() else text
    def a_key(key):
        return [convert(c) for c in re.split('([0-9]+)', key)]
    return sorted(text_lst, key=a_key)
a = ['a1', 'a20', 'a2', 'a10']
vals = natsort(a)
print("natural sort - \n{}".format(vals))
natural sort -
['a1', 'a2', 'a10', 'a20']
... sort of retired...
DanPatterson
    import re
    def convert(text):
    def a_key(key):
vals = natsort(a)
natural sort -
