How do I add a .png to a map for georeferencing?
20359
12-20-2017 04:47 PM
RobertJameson
Hi everyone,
I'm a NOOB to ArcGIS PRO, and have been spinning my wheels for hours on what seems like a really simple thing.
I want to add a png of a blueprint to a map so I can georeference it an trace the walls.
I have figured out how to add images to "layouts" but not maps.
Whenever I go to to Imagery or Insert there is no option to add an image.
Do I need to do something first before I can add an image over the base map? Where do I go to upload this image?
Thank you much!!
DanPatterson_Retired
If you make a new blank map without any basemaps or defined coordinate system, the Add Data should allow you to add the file
From the help
http://pro.arcgis.com/en/pro-app/help/data/imagery/overview-of-georeferencing.htm
and the topics underneath this one should get you going
RobertJameson
Excellent, thank you Dan!
I marked this as 'assumed answered' if it worked then
