HELP XY Coordinates for feature class
867
05-09-2023 08:58 AM
kirdovada
I created a point feature class but when I click the point, there are no xy coordinates. How do I get the xy coordinates to show in ArcGIS Pro? The points are being put on an image with a coordinate system so I'm not sure why there is no xy data.
BarryNorthey
Clicking the Explore tool on a point feature opens a Pop-up that displays the attributes for that point. The coordinates of the point appear at the bottom of the Pop-up in the format as the map display:
You can otherwise add new latitude and longitude fields to the attribute table and Calculate Geometry on each field to populate, or create a single text field and Calculate Geometry with the Property set to Point x- and y- coordinate notation.
