Group points by location and an attribute value
2313
12-02-2021 10:01 AM
learly
I have a feature class of points.  Each point has an attribute "Count".  I want to create groups of points where the number of points and total of the "count" of those points in each group is about the same.
The point is to cut down on travel time between locations but give each rep about the same total "count" between each of their territories/groups
DanPatterson
MVP Esteemed Contributor
you probably want the network analyst extension
Aggregate Points (Cartography)—ArcGIS Pro | Documentation will aggregate based on straight-line distance only,... no sums, no aggregation based on that.
... sort of retired...
