GlobalID inconsistent display
17017
42
10-31-2019 09:28 AM
DougBrowning
MVP Esteemed Contributor
I am seeing that the Attribute Table and the Attributes pane show GlobalID differently. One is all upper case and one is lower.
I would call it a bug.
thanks
Tags (1)
DebSF
I just posted in the other thread about this @DougBrowning then found this one. Very frustrating that it's still an issue 6 years on!
I'm running into this issue in ArcGIS Pro 3.5.0.
I have a point dataset with related table using GlobalID to a GUID field, set it up and Pro, worked okay, uploaded it to AGOL and now when I view in Pro I can't see the related records - if I select a record and click on Related Data, it shows the relate exists but there is no number next to it indicating how many records are related. I can however see the related records using the pop-up window.
The only potential cause I can see is this uppercase/lowercase issue.
PancovaMarketa
There is a BUG-000169450 related to this.
DougBrowning
@PancovaMarketa  Thanks for posting.  Not sure why it took 5 years to get a bug logged I thought it was on the list when I reported in 2019.  I talked to the Pro team about it directly also.
