GlobalID inconsistent display
4900
28
10-31-2019 09:28 AM
DougBrowning
I am seeing that the Attribute Table and the Attributes pane show GlobalID differently. One is all upper case and one is lower.
I would call it a bug.
thanks
MattStarryACE
Using Pro version 3.1.2. Published a service with existing relationship class to AGOL from Pro (3.1.2). Right-clicked on relationship in Attributes pane and selected "Add New To Relationship". It added a record to the related table but it is not recognized because the table is populated with GlobalID and related GUID field in ALL CAPS. Very frustrating that this does not work in "Pro".
Even inconsistent when viewing the table in 'Show Selected' vs 'Show All'.
Show AllShow AllShow SelectedShow Selected
DougBrowning
Bug is still in review.  If you have access to support you can add to it or escalate it.
bcdi
Getting to the end of a very long analysis and this issue is jamming me up hard. For what it's worth, I'm using 3.2, windows 11 via parallels.
Edit: upper-ing (yep) the (correctly lower-ed) GlobalID in the raw file of the join table allowed for a successful join. Still unfun to have to navigate.
ClangDevGuy
Just wanted to share more frustration with another issue that I found with this GlobalID inconsistency. It is even effecting the new Enterprise 11.2 Experience builder application where the internal esri team seems to be having similar issues themselves.
I'm basically using the "Data Actions" to query related records from a feature to a feature table. I have GlobalDs and GUIDs for the relationship and the internal built query for selecting sites now uses a "LOWER" in the where statement:
Ex:
(((LOWER(SiteGUID) = '{f725dad7-5205-41d3-956c-1b1a45ff680f}')))
Result is 0 records now, because this was programmed for the "AGOL" globalIDs and not the "Arcgis Portal" globalIDs.
DougBrowning
Did some digging and it is now been moved to a bug  BUG-000146406.   So some progress at 4 years.  If anyone can escalate please do.
https://support.esri.com/en-us/bug/inconsistent-letter-cases-for-the-global-id-values-betw-bug-00014...
It is not just Pro of course though
BUG
Inconsistent letter cases for the Global ID values between ArcGIS Desktop and ArcGIS Online products.
Last Published: February 18, 2022
ArcGIS Pro
Bug ID Number BUG-000146406
SubmittedJanuary 27, 2022
Last ModifiedJanuary 5, 2023
Applies toArcGIS Pro
Version found2.9.1
Operating SystemWindows OS
Operating System Version10.0 64 Bit
StatusIn Review
Workaround
For relationship class operations, use a GUID field as the destination key.
Bug ID: BUG-000146406
Software:
  • ArcGIS Pro
ahargreaves_FW
On it...this is unbelievable.
DougBrowning
Yes I agree and it has been over 3 years too.  Shows a lack of communication between teams.  I talked to them in person about it a few times too.  no movement which is weird.
DougBrowning
Got this update today.  Of course you cannot change to GUID in 123 land.  They still do not get the problem.
Bug fixes are addressed in upcoming releases or general patches, or they may be addressed as ad-hoc fixes. Enhancement requests are implemented in upcoming releases.
Updates have been made to the following defect which you are associated with:
BUG-000146406 - Inconsistent letter cases for the Global ID values between ArcGIS Desktop and ArcGIS Online products.
Status: Duplicate (Learn More)
Duplicate record #: BUG-000167548
Additional Information: Duplicate of BUG-000167548
Alternate Solution:
Thank You,
MarkWILSON_LLS
Ive only just come across this problem trying to update geometry between local and agol data. talk about frustrating..
Thanks for all your efforts on this one @DougBrowning
FYI - bug fix doesnt work for me as my AGOL Schema is locked (Another bug bear about best practice using joined views on hosted data) . - I did manage to create a string field on the local data with a lowercase copy of the GLOBAL_ID and link the data that way.
mw
