Free Practice Tests for ArcGIS Pro 2025 Certifications (Foundation, Associate, Professional)
1546
10-03-2025 08:33 AM
Layelmam_Mohammed
Hello everyone,
As many GIS professionals are preparing for the upcoming ArcGIS Pro 2025 Certification exams, I wanted to share a set of free practice test resources that I recently developed.
These practice tests are designed to help you:
  • Get familiar with the exam-style questions (scenario-based, multiple-choice)
  • Review core workflows and exam domains (data management, analysis, cartography, 3D, automation, sharing)
  • Identify knowledge gaps with detailed answer explanations
  • Build confidence with timed mock exams that simulate the real exam environment
I’ve organized the tests into three courses, aligned with the certification levels:
:small_blue_diamond: ArcGIS Pro Foundation 2025 — Complete Practice Test Prep
👉 Access here
:small_blue_diamond: ArcGIS Pro Associate 2025 — Full Practice Test
👉 Access here
:small_blue_diamond: ArcGIS Pro Professional 2025 — Full Practice Tests & Exam
👉 Access here
The coupon code FORMASIG makes these courses free for a limited time.
I’d be very interested in your feedback — do these practice tests reflect the kind of preparation you find most useful for Esri certifications? Any suggestions for improvements or additional areas to cover?
Looking forward to your thoughts, and best of luck to everyone preparing for their exams in 2025!
Best regards,
Mohammed Layelmam
TFiegel
First off, thanks for the course.  It's a nice practice aid.  One issue I did run into was on Practice Test 5: Coordinate Systems & Transformation.  The question "To align NAD83 data with WGS84 basemap, you may need a:" has two similar answers.  One is marked as correct, the other is incorrect (and with my luck I chose the one marked as incorrect even though both the answer and explanation are exactly the same).
SjoerdLeenders
Hello Mohammed,
Trying the Coupon Code FORMASIG  I get the message:
"The coupon code entered is inactive or expired."
Should the coupon still be working?
