For some reason, I cannot export, print a layout and package a project, which it was working before. It all stuck in the in progress.
6024
8
02-10-2023 04:23 PM
MatthewPoon
AubriOtis
Ah, ok. So it sounds like it's just taking a long time to export. If the layout is really large or some settings (like DPI) are set really high this can occur because it takes time to process lots of data. Can you share your export settings?
Cheers,
Aubri
MatthewPoon
I can package now but there is an error with mosaic to new raster and the packaging was failed
MatthewPoon
sorry for another update, I can only export map but not scene in the layout
AubriOtis
What problems are you seeing when exporting the layout?
Cheers,
Aubri
MatthewPoon
Hi, thanks for replying. When I export a layout which has the map frame of a scene, it stuck in " in progress " for hours and it keeps going on forever. However, using the map frame of a map is fine.
AubriOtis
Cheers,
Aubri
MatthewPoon
Even when I set to 100 ppi png export hours later and it is still stuck in progress. I tried jpeg, pdf and all of them dont work
MatthewPoon
hi yes I think it works now when I do it in a local scene, thanks!
DougBrowning
MVP Esteemed Contributor
