Fonts different between RGB and CMYK exports?
4714
10
05-20-2022 08:08 AM
Joshua-Young
Honored Contributor
Is it expected behavior to have font and halo thickness change when switching between RGB and CMYK color models for a layout? The issue seems to only be with labels that have a halo applied to them. I tried using labels with no halos and I did not see any significant difference in the appearance of those labels.
I have attached examples of what I am seeing. RGB produces labels where the font is thicker and the halo thinner, whereas CMYK produces labels where the font is thinner and the halo thicker. I thought the color model only affected the colors?
"Not all those who wander are lost" ~ Tolkien
JeremyWright
What is the data type of the label layer in question - are these actually labeling in Pro or are they just labels that are part of a basemap's "reference" layer?
Joshua-Young
Honored Contributor
It seems to be an issue with the labels in the reference layer "Hybrid Reference Layer (Community Maps)". We use that reference layer because we contribute to the Community Maps program and is more correct and current than what Here Maps provides for our area in the regular Hybrid Reference Layer.
I have a layer in the map that has a label with a halo and I do not see any difference other than the expected color variation.
JeremyWright
ok - I'll give it a whirl now.
so to be clear you see the anomalous behavior/appearance ONLY in exports, or also in the view when color management is enabled?
JeremyWright
Testing in the upcoming 3.0 beta and I don't see the problem.  I'll give it a try in 2.9.x too
JeremyWright
can't repro in 2.9.3 either.  need more info...
Joshua-Young
Honored Contributor
I see the issue in PDF exports and in the layout view. I am running ArcGIS Pro 2.9.3. The screenshots that I provided were taken at from Adobe Acrobat at 100% zoom and the screenshots from ArcGIS Pro were taken at 1:1 resolution in the layout view. You can see how the labels are slightly different even though they should be the same size.
JeremyWright
ah ok that was the missing piece - I'll try on layout then.  I was exporting from Map view
JeremyWright
I haven't been able to repro on layout either.  What version of arcGIS Pro are you using?
Joshua-Young
Honored Contributor
I am using ArcGIS Pro 2.9.3. I just realized that the color management is set at both the map and layout level, and I was only changing the color management to CMYK in the layout properties. I changed the map properties to use CMYK for the color schema as well, but I still see the difference in the labels.
