Failed to open map view
59073
84
09-01-2021 11:43 PM
NadaKadhim
Hello everyone,
I have been working for 15 days on an important project. Every step/process that I was working on I saved it. When I open ArcGIS Pro (version 2.8) I found this message.
Please, could you help me in fixing this issue as soon as possible?
I'll highly appreciate your help.
Thank you.
Best regards,
2 Solutions
kathlynmd
I've run into this problem a few times and it looks like others still are as well, so I wanted to offer my stop gap solution that I use. I just open a new blank map within the project and add in all my files/feature classes again from the catalog. It doesn't save your formatting/symbology but usually all of the geoprocessing tools' outputs are saved as files to the project. Not a perfect solution, but something at least.
KoryKramer
Esri Esteemed Contributor
Hi everyone, .aprx files will need to be investigated to determine the underlying issue. Please Contact Technical Support to investigate and support can handle the file on our side to see if it can be recovered. You may also visit the APRX Doctor idea and add your kudos to indicate it is a feature that might help as a self-serve mechanism. Thank you.
NadaKadhim
Any answer/solution, please!
TimOrmsby
Hi, the best course of action is to contact Esri Technical Support if you haven't done so already. This is probably something that needs troubleshooting.
Tim
NadaKadhim
Thanks, Tim for your response. That's right, I contacted them indeed but no reply yet!
DavidPařík
hello! today the exact same thing happened to me.. did you find any solution? i casually saved the project in school but later this day i tried to open the same project at home and "failed to open map view" ...
thanks for any advice!!! 🙂
JayantaPoddar
Meanwhile, could you try the following options?
1. Close all applications. Restart your system.
2. Try opening the APRX file from a fresh ArcGIS Pro instance? Project > Open. Also
3. Save As the project to a new location, and try opening the newly saved file.
4. Share as Project Package. Then extract the package .
Think Location
ChristineSeidel
Hello -- Did you ever find a solution to this issue?  I'm using ArcGIS Pro 3.1.0 and this same thing has just happened with a project I was working on.  Thanks.
- Chris
KrisKarki
I also received same issue today. I did all what  JayantaPoddar advised. But, did not open the map. Any solution yet?
GavinHoward
Found a solution! If you copy and paste the map that fails to open, the new copy will work.
KrisKarki
I tried, did not work. thank you.
