Failed to create - table not multi-versioned
1748
11-09-2023 02:41 AM
AdminSig_VBB
Hello,
Recently, I've been encountering an issue when trying to modify or create entities from Oracle tables in ArcGIS Pro. I receive the following message when attempting to create or modify an entity: "Failed to create (table) This table is not multi-versioned."
However, my table is properly versioned in the geodatabase settings. Do you know how to resolve this issue?
Thanks
sajjady
Hi brother
did you find the solution. I am also facing the same problem
KimberlySteele
I am having the same issue? what is the solution?
JitkaKominácká
The only thing I can see in the internals that would cause this is an nonversioned feature class inside of a versioned feature dataset. Solution is reregister the feature dataset as versioned - this would registered the nonversioned feature class as versioned. Or remove the feature class from the versioned feature dataset and do the edits outside of the feature dataset.
ShariF
We have a recently UN-versioned dataset that is throwing this error. No feature classes are versioned within this dataset any longer. The errors are:
I wonder if there's something hung and we need to run that "Unregister As Versioned" tool just to be 100% sure.
https://www.linkedin.com/in/shariforbes/
