Extracting & Converting XY Locates from PDF to ArcGIS Pro
1615
06-11-2020 07:43 AM
by Anonymous User
Not applicable
Locates that are currently in PDF form. I have exported them to an Excel spreadsheet; they locates were in a single cell, so they need to be separated.
Can anyone offer help with what an ARCADE or Python expression that would select on the Y_Coordinate field based on the starting 85 degrees or the first numbers after the split?
BruceHarold
Esri Frequent Contributor
Hi
This tool might work for you:
Convert Coordinate Notation—Data Management toolbox | Documentation
Also, to work from your source PDF files, the LocateXT extension might be a solution.
by Anonymous User
Not applicable
Thank you, but learning how to use scripts and expressions is more beneficial than a tool.
