Extract by mask issue
3708
6
10-18-2023 01:05 AM
catcrawo
I want to cut .tiff by .shp and chose to use extract by mask. However, the result contains several white stripes as shown in picture. The value in these area are "Nodata", but the original .tiff does have values in these area. I would like to ask how could I solve this problem. Thanks in advance.EBM problem.png
Tags (1)
DanPatterson
MVP Esteemed Contributor
the shape file has issues then if it has those stripes, get the shapefile into edit mode and remove any spurious vertices that are in the interior
... sort of retired...
DanPatterson
Try converting the shapefile to a local file geodatabase featureclass.  Ensure that the coordinate system of the featureclass matches that of the raster.
Any difference when this is followed?
Alternately, convert the shapefile to a raster mask using the procedure outlined here
Solved: Extract by Mask Fail using Feature as Mask - Esri Community
catcrawo
When I converted .shp into .gdb and used Extract by Mask, the white stripes become even more.
When I only converted .shp into .tif without Extract by Mask, as shown in the picture, the .tif itself has included white stripes.
DanPatterson
catcrawo
The shapefile does have issues. Thank you very much!
catcrawo
Excuse me, there is another question.
How could I remove those vertices after getting into the edit mode? I can't find the right tool.
DanPatterson
Edit feature vertices—ArcGIS Pro | Documentation
Add or Delete vertices section
