exporting shp file
802
12-16-2022 07:12 AM
simonlewis1
Hi all
when exporting a shp file from arc gis pro the shp file never exports to 3 decimal places, all numeric fields populate as below - any ideas how to solve this please.
few examples below
1.64000000000e+00 its meant to be 1.64
1.52000000000e+00 its meant to be 1.52
thanks
Robert_LeClair
Esri Esteemed Contributor
Add the shapefile to a map view, select the shapefile in the contents pane, right-click and select Data Design->Fields.  This will open the Fields Designer.  For any numeric field, go to the Number Format column, double click the Numeric term, select the 3 dots and this opens the number format.  Format your numbers for Decimal places to 2.  Click OK.  Your numbers should now just have 2 decimal values such as 1.64 and 1.52.
