I have a Rubbish_Bins feature class in my SDE, this has GlobalID (type is Global ID) column as per below screenshot:
You can see all the global ID's are populated.
I then run the Copy Rows tool in Arc Pro (right click | data | export table):
I open this CSV and I note the global ids are all removed, yet all other columns are populated.
I then tried testing this in ArcMap 10.6.1
I open the attribute table, click export, then use these settings:
Then i get this error:
Note this error is only happening on this feature class (its the only one I have added GlobalID to).
Am I doing something wrong here or is this a bug?
