Export Training Data for deep learning
2884
07-27-2021 01:20 AM
HamzaM
I am trying to export training data for deep learning but i get this error
RuntimeError: ArcGIS Online does not support export_training_data function.
I am not even using arcgis online, i am using arcgis pro v2.8.1.
this is the code i am using
chips = export_training_data(planet_mosaic_data, buildings, "PNG", {"x":448,"y":448}, {"x":224,"y":224},
"PASCAL_VOC_rectangles", 75, "planetdemo")
@JayantaPoddar @AubriOtis @DanPatterson @Robert_LeClair @DavidPike
Tim_McGinnes
It looks like you might be following the steps on this page? Object Detection Workflow with arcgis.learn
It states:
Theexport_training_data()method generates training samples for training deep learning models, given the input imagery, along with labelled vector data or classified images. ... This tool creates folders containing image chips for training the model, labels and metadata files and stores them in the raster store of your enterprise GIS.
You may have specified your GIS connection to ArcGIS Online, or not set a connection at all, in which case it will use ArcGIS Online by default. You will need to connect to ArcGIS Enterprise.
If you want to export training samples to a local hard drive, I think you will need to use the Export Training Data For Deep Learning tool in ArcGIS Pro.
HamzaM
How do i set up my connection to arcgis Enterprise not online, this is the code i used to set up my connection
gis = GIS("https://----.maps.arcgis.com", username="-----", password="----")
Robert_LeClair
Esri Esteemed Contributor
ArcGIS Enterprise is a software system that you purchase and license from Esri.  A base ArcGIS Enterprise deployment is at a minimum ArcGIS Server, Portal, the ArcGIS Data Store and Web Adaptors for the Server and the Portal.  Do you have ArcGIS Enterprise installed within your organization?
