Export to Python file from Notebook
5508
7
07-16-2023 07:58 AM
JohnMorgan
I am running ArcGIS Pro 3.1.2 and working in a Python Notebook. I have several working cells and am trying to export them to a Python script (Export > Export to Python file). However, when I do this, I get the error "Export failed" with no further info.
Any advice would be appreciated.
Derek
Tags (3)
David_McRitchie
Hey Derek,
Would it be possible to get a copy of your notebook so that it can be tested on a different environment.
It would also be worth copying the cells into a new .py file and checking if this works fine.
Many thanks,
David
Esri UK -Technical Support Analyst
MicZatorsky_AEC
My guess, there are spaces in the filename and/or file path.  Test exporting to "c:\temp\mycode.py".
JohnMorgan
I don't have a space in the file name, but I did find a workaround for now. It would be nice to sort out why it isn't working, but perhaps it's just something w/ my installation.  David, for an attached notebook, but it won't let me attach that type of file to this message board.
David_McRitchie
Ah would it be possible to set up a shared folder for the notebook? If not then please message me your email and I can set one up.
David
HeeJinYang
I have the same problem.
Would you let me know how you solved the problem?
JohnMorgan
It has been a while since I looked at this. But, I do recall the workaround of using the command line of nbconvert as described here. https://stackoverflow.com/questions/17077494/how-do-i-convert-a-ipython-notebook-into-a-python-file-...
>jupyter nbconvert --to script [YOUR_NOTEBOOK].ipynb
Ideally, it would just work straight out of ArcGIS though.
BENROLLINCELECHINDEMEFUETNGWOA
Dear John, I faced exactly the same issue. What I did was to, open the arcpy notebook file (.pynb) in Jupyter notebook and export/save as to an executable script (.py). It worked from there.
Thank you.
