Export Raster
2207
6
04-26-2023 12:13 PM
LeahAckerman
I am trying to export a raster, it keeps stating export failed without any error notes.
I have tried PNG, JPG, JPEG, and PDF
SLouq
by MVP Alum
Are you exporting from a File Geodatabase? If so try exporting as a .TIFF
LeahAckerman
Let me try, thanks!
LeahAckerman
Didn't work for me, "Export Failed" I wish it would at least give me the error reason.
SLouq
by MVP Alum
If you click 'View Details' when it tells you Export Failed, it should give you an Error code with a link to a solution
LeahAckerman
As stated, it isn't giving an error message, there isn't a View Details like normal.  Just Export Failed.
AubriOtis
Can you try making a copying the layout to a new project and then exporting? There's an export bug in 3.1 that should be fixed in an upcoming patch with some exports. In the meantime, copying the layout to a new project usually fixes the problem.
Cheers,
Aubri
