Exclude overnight hours in DateDiff calculation
1987
02-28-2024 07:25 AM
MikhaylaB
I've written an Arcade attribute rule to calculate hours spent working on a project. I need to update that script to exclude the hours between 4:01PM and 6:59AM. My code is as follows:
var StartDate = $feature.TimeStart
var EndDate = $feature.TimeEnd
var TimeDiff = DateDiff(EndDate, StartDate, 'hours')
return TimeDiff
Link to previous post:
https://community.esri.com/t5/arcgis-pro-questions/update-integer-field-with-datediff/td-p/1388053#M...
Tags (4)
2 Solutions
KenBuja
MVP Esteemed Contributor
This should work. It calculates the number of days between the start date and end date and subtracts 15 hours for each day.
var DayDiff = DateDiff(DateOnly(EndDate), DateOnly((StartDate)), 'days')
var HoursOff = 15 * DayDiff
return TimeDiff - HoursOff
MikhaylaB
I ultimately didn't need to exclude the overnight hours because I learned the work stops by end of business hours and a new entry is created for the next day. I did have an issue with my field not allowing decimals as a result from my equation, so I changed from a short integer to a double. I wanted hour and fraction of an hour as a whole number + decimal. Final code below:
var Minutes = DateDiff(EndDate, StartDate, 'minutes')
var MinDiff = (Minutes-60)/60
var HourMin= Number(TimeDiff + MinDiff)
return TimeDiff
KenBuja
MikhaylaB
Thanks, that should be good. Might you know how to include hours and minutes, like 2.5 hours? I noticed it rounds down to the closest hour.
KenBuja
If you want the hours just rounded to something like 2.5, use Round function (and template literals)
return `${Round(TimeDiff - HoursOff, 1)} hours`
You can add this to return the hours and minutes
var TotalTime = TimeDiff - HoursOff
var Hours = Floor(TotalTime);
var Minutes = Floor((TotalTime - Hours) * 60)
return `${Hours} hours and ${Minutes} minutes`
MikhaylaB
Hi, I have a question unrelated to this post, but you were very helpful with my last Arcade question. I have two attribute rules that I need to combine, because they are firing in the wrong order as separate rules. I need to first calculate the GPM from a value entered into the Flow field (both are fields in the same related table). I need that GPM value to update a parent feature class in the "class" field. Do you have an idea how I could combine these two expressions?
//Calculate GPM
var flow = $feature["Flow"];
var gpm = 0;
if (!isEmpty(flow)) {
gpm = (29.7 * (2.5 * 2.5) * Sqrt(flow) * 0.9)
return gpm;
//Update Parent Class
var parent_id = $feature.hydrantObjid ;
var parent_class = FeatureSetByName($datastore, "hydrantCopy", ["OBJECTID", 'class'], false);
var parent_records = Filter(parent_class, "OBJECTID = @parent_id");
var updates = [];
var i = 0;
var new_value = 'no gpm';
if ($feature.GPM >= 1500) {
new_value = "Blue - 1500 GPM or Greater";
else if ($feature.GPM >= 1000) {
new_value = "Green - 1000-1499 GPM";
else if ($feature.GPM >= 500){
new_value = "Orange - 500-999 GPM";
else {
new_value = "Red - 0-499 GPM";
for (var row in parent_records) {
// If the parent row is null or has a different value, updated it
if (IsEmpty(row['class']) || row['class'] != new_value)
updates[i++] = {
'OBJECTID': parent_id,
'attributes': {"class": new_value}
return {
'result': parent_id,
'edit': [
{'className': 'hydrantCopy',
'updates': updates
MikhaylaB
return TimeDiff
