Error when save edited attribute table
1754
06-15-2021 01:30 AM
NattasitSrinurak
I am using arcgis pro 2.8.  I changed the text in attribute of shapefile using replace function in attribute table.(figure 1-2).
The replace worked perfectly without any problem. (Figure 3.) but when I save the edited feature, my table data was ruined. The unknown data overwrote the other row of data and it randomly wrote the other empty rows with changed text. (Figure4-5).
I checked with editable status already, this layer is editable.  Any ideas what happen?
Thank you in advance.
DanPatterson
MVP Esteemed Contributor
the dbase portion of shapefiles have poor support for unicode characters.
Do you remember the "replace" syntax that you used?
Geoprocessing considerations for shapefile output—ArcGIS Pro | Documentation
support article
How To: Read and write shapefile and dBASE files encoded in various code pages (esri.com)
... sort of retired...
DanPatterson
support article
NattasitSrinurak
Thank you very much for pointing out. I just exported the shapefile>geodatabase. It's work like a charm. Sorry for my outdated skill. Silly me.😅
DanPatterson
Glad it worked out
