Error joining csv file to feature class
4332
05-02-2022 11:32 PM
DVP
Hello, as the title says I am trying to join a CSV file to a feature class and I keep getting an error 999999. At first, I thought it was because field types were different so once I had them matching up properly I assumed the join would go through, but I still get the same error. It should be a fairly simple join so I am not sure what I am missing that is causing this error to come up. I would appreciate any advice on the matter.
Tags (1)
DanPatterson
MVP Esteemed Contributor
show your inputs.  it could be something with a particular column or a row.
Try making the csv into a geodatabase table first, then try the join is another option
... sort of retired...
RobertBorchert
Honored Contributor
If you are trying to join string fields together make sure your .csv file does not have a length greater than 255
If it does then technically even though it is still a string but it is a type not supported.  One way to determine that is to import the .csv into a database and look at the properties.  .csv fields can have up to 32767 characers.
GoWest
Like DanPatterson said, add your csv to the Contents pane and then immediately export it to a geodatabase table.  Joining a Feature Class to a csv file directly is prone to errors, which is why everyone recommends exporting the csv to a geodatabase table.  If you join a Feature Class to a csv and check the "Index Joined Fields" checkbox, you will always get a ERROR 999999.
It would be nice if we had better error messages when joining Feature Class to a csv. ESRI should disable the ability to join Feature Class to csv altogether.  Having a right click option to import CSV to Geodatabase table quickly would be a nice alternative.
@KoryKramer
JonathanNeal
FYI, added a validation error to let users know text files do not support indexing.  I hope this helps for users in 3.2+
