Error: 6598 ORA-06598: privilegio INHERIT PRIVILEGES insuficiente ORA-06512: en "SDE.ST_GEOMETRY"
622
09-11-2025 07:16 AM
TeresaVillena
In an ArcGIS 10.8.1 environment and st_geometry in oracle 19c whe trying to run "Create spatial type" it givs the following error: db_get_dbms_release:: Unknown DBMS Release (19.0.0.0.0) higher than 18c detected using DBMS_UTILITY.DB_VERSION. SGA_Param - Open_Cursors: 1000 SDE_Oracle Error: 6598 ORA-06598: privilegio INHERIT PRIVILEGES insuficiente ORA-06512: en "SDE.ST_GEOMETRY", line1036
ChrisUnderwood
Hello @TeresaVillena
ArcGIS 10.8.1 requires a minimum of Oracle 19.3. The error message suggests you only have 19.0 ?
https://desktop.arcgis.com/en/system-requirements/latest/database-requirements-oracle.htm#GUID-73C89...
