ERROR 160244: Object has no schema locks. Select by location
9501
16
05-03-2021 05:22 AM
Labels (2)
by Anonymous User
Not applicable
Failed to execute (SelectLayerByLocation).
I noticed it's giving me the error on a multipart polygon. I exploded and it worked. Can I not use multipart polygons?
by Anonymous User
Not applicable
I never found a solution. I ended up exploding the multipart feature so now I use 4 polygons instead of 1. It's definitely broken because I have tried it with different multi-part features and none of them work.
ZacharyHart
Honored Contributor
As I feared. For my particular workflow i need to retain the multipart polygon and even then I'm not sure there is a way to explode via arcpy.
Out of curiosity, what version of Pro are you using?
Pro 2.7.3 and Python 3.7.9 here...
EDIT:
I just tried the same process in ArcMap 10.7.1 (in Python window) with the same exact data and the tool runs without error.
by Anonymous User
Not applicable
I was using 2.7 I think but I have 2.8 now. I haven't tried it yet with the new version.
ZacharyHart
Honored Contributor
I've not upgraded because I just fixed my dev environment upgrading to 2.7.3...so I've not quite worked up the appetite to jump to 2.8 yet!
These are the times I wish Esri actually watched these threads.
No fix for the last 3 versions?
GISAdminGKB
We had the same problem since last week. But we could solve it by setting the coordinate system in the environments tab of the tool.
However we never had to do this before.
ZacharyHart
Honored Contributor
@GISAdminGKB  That's a rather astute observation!
by Anonymous User
Not applicable
Well I just tried it and it seems to be working like it should. I think there was a 2.8.1 update a few days ago so maybe that fixed it.
