Error 0x80040501 when repairing database connection
4078
10-15-2025 02:24 PM
Labels (2)
TaylorsvilleGIS
I keep getting the Error: 0x80040501 when attempting to repair connection to an sde. I inherited the gis work at my workplace and I am unfamiliar with how the databases were constructed. Any help with solutions to this error?
TaylorsvilleGIS
It is to an SQL Server, I believe because I am a new user on this machine something may be up with the credentials or access to the server. This may be a problem I have to solve internally but I figured it was worth a shot to see what the community had to offer, thank you.
Eugene_Adkins
Perhaps this is related, especially if the db's were not created using your computer:
Solved: Error HRESULT: 0x80040501 when adding excel files - Esri Community
There's also this:
Troubleshoot database connections—ArcGIS Pro | Documentation
It may also help if you provide the version of Pro you're using.
MichaelVolz
Esteemed Contributor
What type of database is the connection to (e.g. SQL Server, Oracle, PosrGres, other)?
TaylorsvilleGIS
TaylorsvilleGIS
Thank you I didn't find an answer there, I am using 3.4.3.
