Enable Time on Mosaic Imagery Service?
2765
01-17-2021 06:00 PM
by Anonymous User
Not applicable
Hi all,
I'm having trouble enabling time on a mosaic that i want to publish up to portal (image server) from a registered enterprise geodatabase.
Using ArcGIS Pro, you are forced to publish imagery services via the catalog pane. However I cannot find a way to enable time prior to publication of the imagery service.
I found 'defaults' but that setting does not stick. and upon publish tiem is no longer enabled.
Any assistance would be much appreciated
Cheers,
Cam
AngusHooper1
Use the following GP tool against the mosaic. There are multiple params related to time.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/set-mosaic-dataset-propertie...
AngusHooper1
by Anonymous User
Not applicable
Thanks @AngusHooper1 thats great.
Was having a real hard time finding the right tool or process.
I beleive my issue with the defaults (which should set it like the tool you have suggested) is that I was not the owner of the mosaic in the egdb, therefore when i was setting it with defaults the setting would not attach to the mosaic.
Cheers,
Cam
AnneHillyer
This was super-helpful!!!  Thank you.
