How to iteratively select by unique field values and create new feature
2830
01-22-2021 01:26 PM
PenelopeMitchell2
I am trying to iteratively select by attribute>create feature layer> create new feature class(es) from the selections. But I am getting errors in the Make Feature Layer process.  Any suggestions?
Thanks, Penelope
Update: Edited for code formatting--thanks for the tip.
#obtain unique values
values = [row[0] for row in arcpy.da.SearchCursor(SortiesLnFP, 'RS_Name')]
uniqueValues = set(values)
print(uniqueValues)
#create where clause for .makefeaturelayer using unique Values
#use where query to make a feature layer from selection then convert to feature class
OutPath = wkspc
for value in uniqueValues:
    OutFile = wkspc + os.sep + str(value)
    query = "\"RS_Name = '{}'\"".format(value)
    #query = "RS_Name = " + str(value)
    sortieLayer = arcpy.management.MakeFeatureLayer(SortiesLnFP, OutFile, query)
    arcpy.conversion.FeatureClassToFeatureClass(sortieLayer, wkspc, str(value))
    arcpy.managementDelete(sortieLayer)
#Output of query
"RS_Name = 'Pink_PM'"
"RS_Name = 'Pink2'"
#i've tried w/ the "" and without, get the same error either way-- I saw another post including those for the same purpose so thought I would try it (https://community.esri.com/t5/arcgis-api-for-python-questions/select-unique-values-from-field-using-selectbyattribute/td-p/825616/page/2)
ExecuteError                              Traceback (most recent call last)
In  [67]:
Line 6:     sortieLayer = arcpy.management.MakeFeatureLayer(SortiesLnFP, OutFile, query)
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py, in MakeFeatureLayer:
Line 8668:  raise e
Line 8665:  retval = convertArcObjectToPythonObject(gp.MakeFeatureLayer_management(*gp_fixargs((in_features, out_layer, where_clause, workspace, field_info), True)))
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py, in <lambda>:
Line 511:   return lambda *args: val(*gp_fixargs(args, True))
ExecuteError: ERROR 000358: Invalid expression
Failed to execute (MakeFeatureLayer).
DanPatterson
MVP Esteemed Contributor
DanPatterson
Code formatting ... the Community Version - GeoNet, The Esri Community
will help make your code more readable
BTW
arcpy.conversion.FeatureClassToFeatureClass(SortieLayer
case difference !
... sort of retired...
DavidPike
MVP Notable Contributor
Agreed, the code is very hard to read and unformatted.
No idea if the rest is any good, but it seems that your query is enclosed in another set of quotes, remove those and it should be valid (if value is a string, if its a number - remove the single quotes also).
query = "RS_Name = '{}'".format(value)
DanPatterson
of course there is always
Split By Attributes (Analysis)—ArcGIS Pro | Documentation
PenelopeMitchell2
Thank you very much @DanPatterson for pointing me in the right direction. I cannot believe I've never used that tool, very useful!
Best,
Penelope
