Edit tab
4368
07-27-2023 05:29 AM
vvatcer
I am currently using ArcGIS Pro and wish to create/modify some polygon features that I will use for clipping rasters images.  I cannot seem to figure out how to add the "Edit" tab to my ribbon.  I have read a few posts that mention going through the  options but the it gets confusing.
Tags (1)
JohannesLindner
You shouldn't have to manually add the Edit tab, it should appear automatically.
Ribbon tabs are context-sensitive: they change depending on your active view (e.g. catalog, map, layout) and selection (e.g. select a raster layer vs a feature layer in a map's toc).
The Edit tab should show up when you open a map.
For example, here I am in the Catalog View. The ribbon displays the "Catalog" tab with catalog-related tools. This tab only shows up in the Catalog view.
When I open the map, the ribbon switches the tabs to the ones appropriate for maps, including the "Edit" tab:
Have a great day!
Johannes
JohannesLindner
Have a great day!
Johannes
vvatcer
Thank you so much.  I think my view was not activated.  I was able to complete the task once I did that!
