Draw hatches with Z-values along a line
747
11-17-2023 10:39 AM
1Spencer
Hello! I recently came across this article about drawing measured hatches along lines and wonder if it is possible to perform a similar action using a line's z-values by mapping the text element to the z-values.
What I want is to have each vertex on a line to have a hatch with that vertex's z-value.
I am on ArcGIS Pro 3.1.2
The closest I've gotten to this goal is using this expression in the attribute mapping. However, all this does it return the z value of the first vertex on every vertex on the line.
var line = Geometry($feature);var path = line.paths[0];var pt = path[0];return pt.z
MicZatorsky_AEC
Hatches are specific to m-values.   If you want to label vertices with z-values, I'd look at creating a set of points at vertices using Feature Vertices To Points
MicZatorsky_AEC
