Does ArcGIS Pro 2.7 support operating system authentication with PostgreSQL?
1336
8
02-02-2021 07:39 PM
JesseTemplin2
I have found an older post and documentation for Dasktop10.2, indicating it is unsupported or not recommended. The menu option is available in ArcGIS Pro, but I haven't been able to get it to connect. It's quite possible I'm doing something wrong. But before I spin my wheels too much, can anyone confirm or deny that OS authentication is fully supported for PostgreSQL?
Thanks!
Robert_LeClair
Esri Notable Contributor
From what I've read internally is that OS authentication is not supported when connected to PostgreSQL databases.  There is ENH-000132328 to update the documentation to be more explicit about what's supported/not supported. And ENH-000119762 to enable fully support of OS authentication on PostgreSQL databases, such as allowing OS login name contains special characters.  Hope this helps.
DanPatterson
don't use it so I don't know, but your links are for old help topics, but PostgreSQL has lots of links.
Did you see these?
Database connections in ArcGIS Pro—ArcGIS Pro | Documentation
Connect to PostgreSQL from ArcGIS—ArcGIS Pro | Documentation
Search Result | Documentation (arcgis.com)
... sort of retired...
JesseTemplin2
Thanks for the newer info. No mention of OS authentication in the first two links though. They just say choose database authentication (in bold). Should I interpret that to mean do not choose operating system authentication?
George_Thompson
Esri Frequent Contributor
I would contact Esri Technical support to see if there is any updated information or an enhancement for this capability.
--- George T.
Robert_LeClair
JesseTemplin2
Thanks Robert! Not the answer I was hoping for, but at least I can focus my attention elsewhere now.
soniadickerson1
Regarding special characters in the login name, do you know if using mapping in the postgresql pg_ident.conf would work?  I see some examples in some recordings like this one ( https://www.youtube.com/watch?v=GWb7t8J73Fc ) and have attempted it but can't get it to work yet.
Example of a mapping in pg_ident:
# MAPNAME     SYSTEM-USERNAME     PG-USERNAME
SSPI                     XWikiDBOwner@youraddress     postgres
Then a reference is placed in the pg_hba.conf file
host      all     postgres     127.0.0.1/32     sspi     map=SSPI
Thanks for any insight!
This video tutorial shows how to install PostgreSQL 10 on Windows and use SSPI (password-less logon).
soniadickerson1
I was able to get this to work for postgresql 13 - had to look in the postgresql log files to see what the actual domain was.  Then once it was added to the pg_ident file, I was able to connect using operating system authentication.  Grants and permissions needed to be handled via a sql script but it does work.
MarceloMarques
FYI: community.esri.com - white paper - How to Configure Windows Authentication for the PostgreSQL Enterprise Geodatabase. - Esri Community
| Marcelo Marques | Principal Product Engineer | Esri |
| Cloud & Database Administrator | OCP - Oracle Certified Professional |
I work with Enterprise Geodatabases since 1997.
“ I do not fear computers. I fear the lack of them." Isaac Isimov
