Display XY not letting me select an X field or a Y field
1178
07-20-2022 12:49 PM
SLouq
by MVP Alum
I am stumped. I've used this tool before and it always worked but now it's not.
I am trying to Display XY data in my map. I have an Excel spreadsheet which has lat/long coordinates in it split into it's own column but when I open the Display XY Data for the Excel table in ArcGIS Pro, it is not giving me an option to select an X field or a Y field.
Why is this?
Tags (1)
DanPatterson
MVP Esteemed Contributor
open the table properties and ensure that the field is numeric (float or double)
... sort of retired...
DanPatterson
SLouq
by MVP Alum
I tried setting the field type to Double but then it just doesn't reconize the coordinates. Never tried float. Anyhow I've resorted to manually typing in the coordinates in new columns in Excel. That way it reconizes it as a Double field.
Thanks!
