Whenever I build a successful expression for the display field in Pro and then publish it, I check the REST and the display field is always blank. We are using Pro 3.1 and Enterprise 10.8.1. Any reason for this happening?
Solved! Go to Solution.
This looks like it is a conformed bug for the edit widget in ExB: https://community.esri.com/t5/arcgis-experience-builder-questions/edit-widget-form-integration/td-p/...
