Display Field in Pro Will Not Publish When Using an Expression
953
12-27-2023 01:32 PM
ArmstKP
Whenever I build a successful expression for the display field in Pro and then publish it, I check the REST and the display field is always blank.  We are using Pro 3.1 and Enterprise 10.8.1.  Any reason for this happening?
ArmstKP
ArmstKP
This looks like it is a conformed bug for the edit widget in ExB:  https://community.esri.com/t5/arcgis-experience-builder-questions/edit-widget-form-integration/td-p/...
