Different behavior when importing XML Workspace Document with ArcGIS Pro vs ArcPy
1255
06-22-2023 07:20 AM
by Anonymous User
Not applicable
I'm trying to import a schema XML file into a Geodatabase. Doing this with Pro gets the output I expect, but not with ArcPy. The fields are almost completely broken.
  • All non-Text fields automatically become Text.
  • All Text fields automatically have a maximum length of 65,536 characters.
ArcGIS Pro workflow
  • Add Database
  • Import XML Workspace Document
  • Set paths for GDB and XML
  • Import schema only
  • Leave Configuration Keyword empty
Python code
ap.management.ImportXMLWorkspaceDocument(GDB_PATH, XML_PATH, 'SCHEMA_ONLY')
Are there some configuration settings that Pro handles under the hood that I need to set as well? Is this a common workflow others have used as well?
Thanks for the help.
A
Tags (3)
