Detect Objects Using Deep Learning raster error
1487
6
03-27-2025 10:58 AM
BryceGardnerIA
Can anyone make sense of this error. I am trying to detect objects on a historic map.
A raster error has occurred. The messages that follow will provide more detail.
Python raster function is unable to vectorize the data. [Failed to generate table]
  File "C:\Users\bgardner\AppData\Local\Temp\ArcGISProTemp28396\CentralSouth.dlpk\ArcGISObjectDetector.py", line 218, in vectorize
    polygon_list, scores, classes = self.tta_scale_detect_objects(
  File "C:\Users\bgardner\AppData\Local\Temp\ArcGISProTemp28396\CentralSouth.dlpk\ArcGISObjectDetector.py", line 293, in tta_scale_detect_objects
    polygon_list, scores, classes = self.tta_detect_objects(
  File "C:\Users\bgardner\AppData\Local\Temp\ArcGISProTemp28396\CentralSouth.dlpk\ArcGISObjectDetector.py", line 370, in tta_detect_objects
    pixelBlocksCopy["raster_pixels"] = (out.data * 256).numpy()
  File "C:\Users\bgardner\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\fastai\vision\image.py", line 214, in data
    return self.px
  File "C:\Users\bgardner\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\fastai\vision\image.py", line 145, in px
    self.refresh()
  File "C:\Users\bgardner\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\fastai\vision\image.py", line 132, in refresh
    self._px = _grid_sample(self._px, self.flow, **self.sample_kwargs)
  File "C:\Users\bgardner\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\fastai\vision\image.py", line 156, in flow
    self._flow = _affine_grid(self.shape)
  File "C:\Users\bgardner\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-2\Lib\site-packages\fastai\vision\image.py", line 547, in _affine_grid
    N, C, H, W = size
ValueError: not enough values to unpack (expected 4, got 3)
Python Raster Function's .vectorize() method returned nothing.
Failed to execute (DetectObjectsUsingDeepLearning).
Failed at Wednesday, March 26, 2025 2:41:38 PM (Elapsed Time: 45.01 seconds)
DanPatterson
MVP Esteemed Contributor
via code or the builtin tool?
Detect Objects Using Deep Learning (Raster Analysis)—ArcGIS Pro | Documentation
You may have to track back the error to its source during the creation process to get at the one thrown by which-ever method you used.
... sort of retired...
BryceGardnerIA
Hi Dan! Thank you. This is using the built-in tool. I don't know how to track it back since it's built-in.
DanPatterson
By track back, I meant the procedures under the Usage section.  This ensures the inputs are correct for the tool
ShivaniPathak
Hi @BryceGardnerIA, could you please confirm which model architecture (i.e. MaskRCNN, SSD, RetinaNet, etc) are you using?
adsilb
@BryceGardnerIA were you able to work around this at all? I'm running into the same issue on all model runs using Pascal VOC metadata. I'm able to get RCNN Masks to work, but that is basically limiting the types of model I can create. Thanks!
ShivaniPathak
Hi @adsilb, are you still facing this issue? Can you please tell me which ArcGIS Pro version you are using and how did you created the deep learning environment.
