Definition query to show every nth record plus the last record
1639
08-06-2024 08:28 AM
MattHowe
I have a line layer together with a point layer representing a mark every 1m along the line. Essentially KPs along a cable route starting from say 0 to 50. As well as a point every 1m there is a point at the end of the line. For example 1, 2, 3, 4, 5 ... 47, 48, 49, 50, 50.4 if the line isn't exactly 50m in length.
A query of MOD(MP, 10)=0 will give me a point every 10m but doesn't include the last point.
How can I create a query that displays a point every nth value PLUS the end point.
AlfredBaldenweck
MVP Regular Contributor
If it's in an enterprise gdb, try adding a
OR MP in (Select Top 1 MP from TABLE)
If in a file gdb, I don't think it's possible
AlfredBaldenweck
AlfredBaldenweck
Oops. This will only work for one feature at a time. Add a GROUP BY or other aggregate function to make it work.
MattHowe
Thanks @AlfredBaldenweck. Initially it will be a FGDB so I'll make a note there'll be a bit of elbow grease needed.
Bud
Esteemed Contributor
Idea: ROW_NUMBER function in FGDB SQL
As a very last resort, you could temporarily copy the data to a mobile geodatabase, and then use SQLite SQL to select the rows you want.
StephenKing3
If you know your last KP value you can add an OR statement to the end of the expression to show the last vale, e.g. MOD(MP, 10)=0 OR MP=50.4
This works for a layer in an FGDB.
Thanks to an old GIS Stack Exchange post labeling - Attribute Query for First/Last record and every nth inbetween - Geographic Information Sy...
