Deep Learning: cannot get arcgis.learn.install() to work
1755
02-18-2022 06:21 AM
lkline97
I am attempting to save a deep learning model to my arcgis online account using arcgis.learn, then install the model to run on a raster. However, using the Model() function outputs <empty Model> even after I am able to fetch the model, and .install() outputs:
RuntimeError                              Traceback (most recent call last)
In  [86]:
Line 1:     detect_objects_model.install()
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\learn\__init__.py, in install:
Line 1412:  "model object should be created from a portal item or a portal url"
RuntimeError: model object should be created from a portal item or a portal url
I've set up my gis using my university portal and logged in successfully. I'm not sure why this is happening; it's doing this for every model.
import arcgis
import sys
from arcgis import GIS, learn
from arcgis.raster import analytics
from arcgis.raster.functions import extract_band, apply, clip
from arcgis.raster.analytics import list_datastore_content
from arcgis.learn import SingleShotDetector, prepare_data, Model, list_models, detect_objects
arcgis.env.verbose = True
from arcgis.geocoding import geocode
import os
from pathlib import Path
gis = GIS('https://umainegis.maps.arcgis.com/', '#####', '#####')
data_path = Path(r"I:\Other Maps\Deep_Learning\dl_trial1")
data_path
data = prepare_data(data_path, {0:'GBBG', 1:'HERG', 2:'DCCO'}, batch_size=162, no_check=True)
data.classes
data.show_batch()
ssd = SingleShotDetector(data, grids=[8], zooms=[1.0], ratios=[[1.0, 1.0]])
ssd.lr_find()
ssd.fit(10, lr=slice(2e-3, 3e-2))
ssd.show_results(thresh=0.8)
ssd.save('BirdDetector-ssd3', publish=True, gis=gis)
detect_objects_model = gis.content.get('4f22749c8265400ea560303dd708b90b')
detect_objects_model = Model(detect_objects_model_package)
 ArcGIS version 2.9.1.
DanPatterson
MVP Esteemed Contributor
Are you using these frameworks and instructions?
Esri/deep-learning-frameworks: Installation support for Deep Learning Frameworks for the ArcGIS Syst...
... sort of retired...
lkline97
Yes, I've installed the deep learning installer (2.9) and all of the corresponding packages are installed. I was able to create a model, but I cannot use the following lines without throwing the runtime error provided above:
Tim_McGinnes
The main problem is that detect_objects_model_package is not declared or populated anywhere in your script.
It should be something like (from this answer)
detect_objects_model_package = gis.content.get(item_id)
detect_objects_model.install(gis=gis)
 You have hardcoded the AGOL ItemID as well - are you sure that's the correct one? Running the script again will probably give you a new ItemID each time.
