Help with Calculating Percentage
4704
02-21-2022 04:03 PM
TheACG7
I am attempting to calculate the area of shade as opposed to no shade in an area.
I have created the table which has two objects: 'Shade' and 'No Shade'. I then have a field for the total area for both of these objects. I now want to calculate the percentage for these two objects. I have created a 'Percent' field and am now attempting to calculate the field. The total area for 'Shade' and 'No Shade' is 171,808.9.
The code I am running is: !SUM_Shape_Area! / 171,808.9 * 100
When I run this, I get no error messages, however the Percent field remains NULL.
While trying to figure out the issue, I ran a simpler code of !Sum_Shape_Area! / 2.
This ran fine and resulted in the Percent field simply having a value of half of the SUM_shape_area field.
Does anyone know why this percent calculation is not working?
Thanks!
DanPatterson
MVP Esteemed Contributor
Is see... try dumping the comma in the number, it is yielding unexpected results if python is being used
1000/1,000
(1000.0, 0)
1,000/1,000
(1, 0.0, 0)
1000/1000
1.0
... sort of retired...
DanPatterson
Are you doing this on a row by row basis?  it isn't clear from your question.
If you want if for the table, then see
Summary Statistics (Analysis)—ArcGIS Pro | Documentation
TheACG7
I am attempting to calculate this for the table using the Calculate Field function from within the attribute table. I have attached photos of my code and the attribute table. I have seen others successfully calculate percentage for their tables using this method. I am just confused as to why the table is not responding correctly.
DanPatterson
1000/1,000
(1000.0, 0)
1,000/1,000
(1, 0.0, 0)
1000/1000
1.0
TheACG7
Thank you! Just a simple overlook on my part.
