Creating tpk files in Pro 3.1
5714
14
05-02-2023 11:31 AM
MarkHammond4
In Pro 2.95 I can successfully create a tpk file but when I try it in Pro 3.1 with the same input and settings it gives the error "001461: failed to package tiles". Any ideas why?
Tags (1)
ThomasPe
I only get this error message when the Area of Interest input feature is in a different projection to the output tile package. When the "Package for ArcGIS Online" option is selected, the Area of Interest input feature projection needs to be WGS 1984 Web Mercator (auxiliary sphere) (EPSG 3857).
I'm on 3.1.2.
Brian_McLeer
MVP Regular Contributor
There looks to be an update on the BUG article from 7/30/24 that provides a workaround:
Workaround
Remove the feature from the Area of Interest parameter and put it in the Extent parameter.
However, the Extent parameter does not honor the extent boundary.
https://support.esri.com/en-us/bug/the-error-message-error-001461-failed-to-package-tiles-bug-000163...
I had the same issue and the workaround worked for me.
AnttiMansikka
... and worked for me, too.
TBreazeale_Tract
This may not work for you, I'm a bit of a layman in the complexities of how these processes work but I found that when I was hitting this error it was typically triggering at the parallel processing step. I set the Parallel Processing Factor environment parameter to 0 and it ran successfully.
Sam_Schroder
This fixed it for me, I installed the new version 3.5.2 and then got a different error 003713, that mentioned parallel processing, so I tried 66 (instead of suggested 50), then 0, 0 worked! well it's working for now and hopefully will make it all the way!
