I'm customizing the symbology for a slope map. I'm trying to set a specific color to a range of values.
For example I want:
0-5 degrees: green
5-10 degrees: yellow
etc.
I've changed the symbology as seen here in the screen shot:
When creating the labels should I assign values by increment 0,5,10, 15 etc and will the values in between the increments be assigned those colors?
For example If i have value 0 set to green and value 5 set to green will values 1, 2,3, ... also be set to green.
If not, how can I set a specific range of values to a color?
I have solved this by choosing the "Classify" option under Primary Symbology.
