Creating new network datasets in ArcGIS Pro
11947
22
11-24-2016 09:20 PM
ColinStewart1
Is it possible yet to create new network datasets in ArcGIS Pro, much as you can via ArcCatalog? I understand that it wasn't possible a year ago, but has anything changed since then? If it is possible, what are the steps? If not, is this a feature that we can expect to see in the near future?
Alternatively, is it possible to make a new dataset via the "Create Template From Network Dataset" and "Create Network Dataset From Template" tools? I'm imagining creating a generic XML template from an existing network via the first tool, then modifying the XML to allow the template to be used to generate a new dataset via the second tool with a completely different set of input features (lines and junctions). Is this possible?
Much appreciated.
-Colin
KoryKramer
Esri Esteemed Contributor
That is now in the near-term of the ArcGIS Pro Roadmap
It isn't in ArcGIS Pro 2.4 which will be available in the next week or two, but I believe the plan is for it to be complete in the following release, ArcGIS Pro 2.5.
AlistairHart
So in 2020 in ArcGIS Pro 2.5.0 (downloaded today) is this still not possible?
