Creating new network datasets in ArcGIS Pro
11944
22
11-24-2016 09:20 PM
ColinStewart1
Is it possible yet to create new network datasets in ArcGIS Pro, much as you can via ArcCatalog? I understand that it wasn't possible a year ago, but has anything changed since then? If it is possible, what are the steps? If not, is this a feature that we can expect to see in the near future?
Alternatively, is it possible to make a new dataset via the "Create Template From Network Dataset" and "Create Network Dataset From Template" tools? I'm imagining creating a generic XML template from an existing network via the first tool, then modifying the XML to allow the template to be used to generate a new dataset via the second tool with a completely different set of input features (lines and junctions). Is this possible?
Much appreciated.
-Colin
Torstein_S_Throndsen
Thanks for the update, Robert!
JaySandhu
I just want to clarify that Utility Network capabilities in Pro do not have anything to do with Network Analyst or Network Datasets. Utility Networks are for modeling and analyzing networks with flows such as electric networks. Network datasets are for modeling and analyzing transportation networks.
The ArcGIS Pro 2.1 release will not have the capability of creating new network datasets with a wizard. There will be more capabilities for viewing the network dataset properties (costs/restrictions) and you can continue to create network datasets with a template from the schema of an existing network dataset.
Jay Sandhu
BenjaminOrpilla
Hi Jay Sandhu‌, Any news on when the 'Create New Network Dataset" will be available in ArcGIS Pro? Are there any alternatives that I can do? I don't have any previous network data so using an XML template is out the options.
Cheers,
Benjie
tmaptmap
Hi Jay Sandhu, I was wondering if the capability to create a new network dataset is already available in ArcGIS Pro 2.1.
Many thanks,
Tiago
GabrielaWaesch1
At the moment, Arc Pro 2.1 does not have the capability to create a new network dataset. Apparently, that is still being worked on
AhmadSALEH1
ArcGIS Pro 2.2 Still does not have the capability yet !!!
BenjaminOrpilla
Nope... capability is not there yet
JaySandhu
The network dataset creation wizard in ArcMap is very extensive and we are working hard towards getting all the network dataset property page UI/UX into ArcGIS Pro. So the ability to create network dataset with all these capabilities is still not there. In the meantime this blog may help some users:
Create a Local Government Network Dataset
Jay Sandhu
DanPatterson_Retired
nice and hot off the presses too!
PeterCorlett1
Hi all,
It has been a couple of years since this thread started and there seems to have been no change. I use ArcGIS Pro exclusively now, so how can I create a new Network Dataset from scratch?
Cheers,
Pete
