ArcGIS Pro Roadmap - February 2019
Document created by KKramer-esristaff Employee on Feb 14, 2019Last modified by KKramer-esristaff Employee on Feb 14, 2019
Version 2Show Document
  • View in full screen mode
ArcGIS Pro 2.3 was released on January 24th, 2019. For information on the latest patch, see the ArcGIS Pro Release Notes.
Our goal is to build the best GIS software available. This ArcGIS Pro Roadmap* gives you a sneak peek of what we're focusing on for the near, mid and long-term of ArcGIS Pro development.  This gives our current estimate of when each capability will be released. Some new capabilities will be made available for testing through Early Adopters Programs prior to a release. We'll revise the roadmap throughout the year to ensure it reflects the latest information.
What would you like to see next in ArcGIS Pro? Share your ideas on the ArcGIS Ideas site.  See Ideas in ArcGIS Pro 2.3 for customer ideas that were included in this release.
* Capabilities on this roadmap are tentative and subject to change, delay, or cancellation. The continued development or release of a capability is at the sole discretion of Esri.
ArcGIS Pro Roadmap February 2019
Near-term (next release or two)
Parcel Management - The new generation parcel fabric will introduce 2D/3D editing capabilities and a simpler more efficient approach for parcel maintenance. The new generation of the parcel fabric can be edited from the entire ArcGIS Platform and maintained using the new improved editing functionality of ArcGIS Pro.
Offset printing - Color management, spot color support, and support for overprints and knockouts used in offset lithography and commercial printing processes.
Parallel desktop geoprocessing using SparkSpatial-temporal analysis tools that run across multiple cores on a single desktop machine, resulting in increased performance.
Dynamic Feature BinningDynamic grouping of features as tessellating hexagons or squares in order to visualize areas with greater and lesser numbers of features when displaying data at varying scales.
Projects in the Enterprise - Share and collaborate more effectively with others in your organization.
Raster Pixel Editor  - Tools enabling interactive DEM editing, thematic raster editing, and image redaction.
Tie Point ManagerTools to analyze coverage and examine the quality of auto generated tie points, with support for manually adding or removing tie points to improve adjustment quality in ortho mapping.
Geoprocessing leveraging spatial databasesNew options to run certain geoprocessing tools like Buffer, Spatial Join, Select, or Intersect as queries in databases that support these operations, which will result in improved performance.
Voxel LayerExplore large multidimensional space time voxel cubes for scientific applications.
Materials (point symbols)Support for materials and texture properties for point symbols to support reflectivity, roughness, and other renderer properties that will allow ArcGIS apps to assign realistic materials to objects in 3D scenes.
Mid-term (next two or three releases)
Animated symbolsSymbols that dynamically change to show direction of movement, change in intensity, or fluctuations in value to support scientific temporal visualizations.
MaterialsCross-platform support for materials and texture properties to support reflectivity, roughness, and other renderer properties that will allow ArcGIS apps to assign realistic materials to objects in 3D scenes.
Multipatch editing in StereoAbility to modify multipatch vertices, edges, and faces in the 3D stereo editing environment.
Heat ChartA calendar grid that shows hotspots of data over time, using categories like day of the week or day of the month.
ModelBuilder to PythonInteractive Python snippet generation as you build a model. Can be exported to Python script file (.py).
Geoprocessing schedulerChoose to run your tool immediately, or select a date and time in the future to run it, as well as recurrence.
Layer blend modes - Control the appearance of layers by blending content using a variety of blending modes.
Presentations - Create and share a collection of map and scene views along with titles, graphics, and descriptive text as presentations.
GPS SupportConnect, collect data, and update positions directly from a GPS device.
Dynamic Feature ClusteringDynamic grouping of features as proportional symbols in order to visualize areas with greater and lesser numbers of features when displaying data at varying scales.
Voxel layer sharingShare Voxel Scene Layers across the platfrom for use in web, desktop and mobile apps.
Python NotebooksA new Python coding experience integrated into ArcGIS Pro, that allows you to create and run local or portal-based Python notebooks in an interactive interface.
New Extensions
Aviation: Charting
Roads and Highways
Long-term (in the plan but not assigned to a release at this point)
Terrain EditingEdit features participating in a terrain data set.  Add, remove and replace data referenced by terrains.
3D Mesh as GroundThe ability to use integrated mesh or TIN information as a true triangulated ground surface that would be more precise than our raster surfaces and allow structures such as tunnels and mines.
High Fidelity rendering - The ability to use material properties for smoothness, glossiness, roughness, and other characteristics to render realistic textures in 3D scenes.
For more information on the current release of ArcGIS Pro visit http://pro.arcgis.com
11 people found this helpful
    Outcomes
