Creating a network dataset is not available in my version although I have the extension.
2499
07-19-2023 05:20 AM
Felra123
Hello everyone,
I would like to create a network dataset from a .shp file, but the tool "Create Network Dataset" doesn't appear in Geoprocessing (first pic). I am supposed to have the Network Analyst extension installed (second pic)
Anyone else already had a problem like this one ?
I really need to get this Network Dataset for my work.
Thank you in advance if you have a lead !
create network dataset.PNGcreate network dataset.PNGnetwork extension.PNGnetwork extension.PNG
Taylor_GA
Try navigating through the toolboxes.
  1. Click on the Analysis tab from the ribbon
  2. Select Tools
  3. Click on the Toolboxes tab at the top of the Geoprocessing pane
  4. Expand the Network Analyst Tools toolbox
  5. Expand the Network Dataset subset
  6. Find and select Create Network Dataset
Also, it looks like some tools show in English while others show in French. The Create Network Dataset tool may be one that shows in French. It may show if you search for the name in French instead of English.
DanPatterson
just navigate the toolsets
... sort of retired...
AnadEspiney
I'm having the same problem. Did you manage to solve it? The replies to your answer don't help since they assume that you just don't know where to look for it. Please let me know if you could solve the problem. thanks.
