Creating a Network Dataset in ArcGIS Pro
14646
14
08-21-2018 05:06 PM
BenjaminOrpilla
Is there a way I could create a network dataset from shapefile or features in ArcGIS Pro?
I do have the Network Analyst license but it seems the options that are on many examples in Arc Map are not showing in Pro.
Cheers,
Benjie
FengchaoGu1
Can we also expect to create the network dataset automatically in ArcGIS Pro?  Like remembering the settings and use it for different scenarios.
MelindaMorang
If you want to create a network dataset automatically with specific settings, the best thing to do is to create it once manually (currently only possible in ArcMap) and create a template from it.  Then, in the future, you can re-create a network with identical settings, with the same data or different data, using the Create Network Dataset From Template tool.
SCVTAMarketing
Hi Melinda,
Was the functionality to create a network dataset implemented in ArcGIS 2.5?
DanPatterson_Retired
MobushirrKhan
Hi Melinda, i am using ArcGIS Pro 2.7 but still i can't create network data set using shapefile. i have tried importing the shapefile in geodatabase as feature class.
Any solutions? Kind Regards
