Create unregistered standalone FGDB table
1191
12-15-2023 07:55 AM
Bud
Legendary Contributor
Is there a way to create a standalone table in a file geodatabase where the table is not registered with the geodatabase? For example, using a geoprocessing tool, ArcPy, etc.
Use case - testing:
  • Esri Case #03506437 - ArcGIS Pro 3.2: How-to determine if an item is registered with a GDB or not ?
  • BUG-000163772: Views in file and mobile geodatabases do not indicate in their Data Source properties if they have been registered with the database
Bud
Bud
Yes, use the File Geodatabase API:
Create standalone table in FGDB (using API)
