create point from attributes to a polygon
1097
02-05-2024 01:01 PM
danielholtz
Hi-
I was able to use feature to point toolbox to exact the names of my polygons into a new layer with that data. I need to also extract/create another set of points from another column of data.
In other words- i have 900 polygons with different attributes such as acres. How can I create a point/layer with just the acres so they will show up as text? (i want to export as a kml the label/text of acres and others)
Thank you!
Ed_
by MVP Regular Contributor
Hi Daniel, good morning, maybe use the `Feature to Point` tool to convert the poly to point. Then turn on the labels and select `acres` under labeling class. You can also watch this video, maybe it will help too. You might also wanna look into this article, Labels do not appear in Google Earth after converting to KML.
Cheers
Question | Analyze | Visualize
