Create ArcReaded project from ArcGIS PRO
2699
03-30-2021 03:43 AM
VHolubec
Hello,
don´t you know if there is a way how to export map/scene to PMF file to use in ArcReader.
From my observation it seems, that there is no way how to do it. But I am just checking if someone, after all, hasn´t find any solution?
Thank you.
Vladimir
Vladimir
Tags (3)
KoryKramer
Esri Esteemed Contributor
There is no designed way that I know of.  The new pattern is to share mmpks or web layers/web maps.
KoryKramer
AndyWells
Kory
If one is trying to transition away from ArcReader, what software does the end user need to use in order to work with the MMPK files and have a good printing option? While I would love to go to an online solution, the lack of a good printing option for online is keeping us from doing so. So I am still looking at something with the functionality of ArcReader, that can view a complex map, and print it with a specific layout. The end users have no ESRI licensing at all currently. I'd love to hear your thoughts.
Thanks
Andy
VHolubec
Thank you @KoryKramer for prompt answer!
Vladimir
