Project map on the fly button
927
05-19-2021 11:28 AM
by Anonymous User
Not applicable
Hi All,
I am looking for a button or code that will allow a user to change the projection of a map on the fly. There exists a Set Coordinate System(Set SRS) button within the Georeferencing toolset that does exactly what I want, but the button is greyed out unless you start a georeferencing session.
Is there an existing command, or some code that can be attached to a button that would imitate the georeferencing Set SRS button without having to start a georeference session?
Tags (1)
